How to Maximize the Benefits of Your Custom Truck Cover
16 Apr 2018
Most Ford truck covers are designed to protect your truck from sun damage and harsh weather. The problem with covers usually stems from misuse or purchasing the wrong one for the truck’s needs.
Custom Truck Cover
If you really want to get the most out of your truck cover, use the following tips when making your purchase.
Select the Right Cover for Your Needs
If you own a Ford truck, chances are high that you use it to haul heavy loads or to have plenty of power and traction when heading off-road. If your truck is more modern and you use it often, you probably want to look for all weather truck covers, such as the Superweave Premium from California Car Cover, to give your vehicle ample protection from the elements. An older Ford truck that will be used strictly as a show car would more likely benefit from indoor storage and a special custom truck cover to protect it from dust and moisture.
Apply the Cover Correctly
The next step to maximizing the benefits of your custom truck cover is to apply it correctly. Some Ford truck covers may have mirror slots to really hug every curve of your truck. If this is the case, you need to cover the mirrors first, then pull the cover around the rest of the vehicle. A custom truck cover will sit in place better than a universal truck cover.
Clean the Cover Regularly
You might think you can just leave the cover on your truck for as long as you want and never worry about it again. However, if you really want to use the cover to keep your vehicle clean, then you need to clean it regularly as well, particularly if it is used to cover a truck outdoors. A cover you can throw in your washer might be easier to maintain than one that requires special hand washing methods. For a wide selection of truck covers for many needs and climates, search the options available at California Car Cover.
Image Source: Flickr
Pradeep
I am Pradeep, an avid traveller and blogger. Exploring new places and sharing my experiences with people is my passion.
