How To Increase Manufacturing Output And Clients Simultaneously
22 Mar 2017
Smart Manufacturing
The Internet of Things provides data collection, analysis, and processing with greater speed, efficiency, control, and visibility than ever. It’s natural that such innovations would soon be applied to manufacturing; where speed, control, and visibility are integral components of profitable operations.
Together, such tech development is referred to as “smart” manufacturing. With IoT, you’re able to collect data pertaining to your operational systems in real time. This allows you to maximize your investments in manufacturing equipment. You’ll be able to visibly detect proper operation, or erroneous operation, find the problem, fix it, and keep producing.
Think of “smart” manufacturing as acquiring the data requisite to truly fine-tune your operations. What’s more, innovations that analyze such data are continuing to develop. The cutting edge continues to swing, by no means is it stationary. Like a blade swung in an attack maneuver, as it grows closer to finishing its arc, it becomes more faster, and more powerful.
There’s no telling where the end of current cutting-edge trends lies, but what is certain is that this historical development will only continue to increase exponentially until it reaches that point. Some have called it “the singularity”, and expect that an Artificial Intelligence will become self-conscious in ways that fundamentally transform the planet. Others think that’s sci-fi nonsense.
What’s sure is that technology is developing faster than expected, and the trend is only continuing. To retain your own competitive edge in a market defined by “the cutting edge” earlier described, you’re going to need solutions that give you maximum efficiency in manufacturing. You’ll attain more clients if you can preserve time to meet their needs.
An Upward Spiral
The more clients you obtain, the greater your profitability. In this way, “smart” manufacturing solutions essentially pay for themselves over time. The faster you advance, the more speed and control you can bring to your manufacturing processes. Such fine-tuning can only happen when operations are visible.
You’ll need a solution that provides Manufacturing Execution System, or MES, software which isn’t overly complicated in operation. It must provide requisite data; and not just any data, but the right data. If you don’t have the data, you can’t use “smart” systems to their maximum potential. It makes the most sense to find solutions designed specifically with this in mind.
When you’re looking for the best manufacturing analytics software, AIScorp’s FactoryLogix has been defined around the principle that: “The greatest value of MES is in the information it makes available.” With such a starting point, they’ve developed solutions with speed, visibility, and control defining their implementation.
Overcoming The Competition
Competition in manufacturing is fierce. To retain your biggest clients, you’re going to have to offer the best solutions. If you run a manufacturing facility that specifically produces its own output, you’ll likewise want to spend the least amount of money for the most possible benefit. The best way to minimize costs is by running an organization whose effectiveness is maximized.
The best way to maximize operations is to use new tools as they become available. Your competition will be doing this precise thing, and if you’re not able to match their efforts, there is a high propensity they’ll either produce superior competitive products, or snatch some of your clients away.
Identify areas where you can streamline operations and apply cutting-edge solutions like those of the MES variety referenced earlier in this writing, and you’ll be able to streamline your manufacturing in such a way that there’s more time for additional clients; or at the very least, increased output at decreased time investment.
Images via Pixabay
