Setting up a medical lab involves a ton of equipment – from furniture and storage spaces to tools and machines. However, the essential things of your medical lab are the latest microscopes, analyzers, and other relevant devices. It would be best if you had the most recent medical lab instruments to ensure your facility could carry out complex biological, chemical, microscopic, hematological, and immunologic tests each day.
Today, I will share detailed information about equipping your medical lab with the latest instruments. Read on:
Why Do We Need the Latest Medical Lab Instruments?
Before we talk about the latest devices for your lab, we should first understand why we need them. Medical lab instruments use top-grade technology to test biological substances and use the results to diagnose or treat various health conditions. These substances can include blood, urine, or even genes. Professionals use medical instruments in the lab for blood banking, urinalysis, body fluid analysis, microbiology, chemistry, and serology tasks. Here are some of the benefits of using the latest instruments:
  • The latest medical lab instrument technology helps diagnose, prevent, and even treat diseases.
  • You get higher accuracy with high-quality tools.
  • The latest devices will ensure efficient, consistent performance in your medical lab.
Different Types of Medical Lab Instruments
There is a plethora of medical instruments out there, each with a unique objective. Testing, analysis, and diagnostic capabilities of your lab will depend on the array of devices available. If your clinical or medical facility aims to complete a wide range of functions and deliver timely, accurate reports, be sure to cover all types of medical lab instruments.
In any well-established medical lab, you’ll see the following:
a) Microscopes
This basic apparatus is for analyzing blood cells and urine. The observer checks the substances and distinguishes any abnormalities.
b) Blood gas analyzers
Blood gas analyzers are for measuring the amount of Carbon Dioxide, Oxygen, pH acidity, and other parameters in the blood.
c) Hematology analyzers
These analyzers count white blood cells, do complete blood counts, and can run a variety of other tests on the blood as well.
d) Centrifuges
Centrifuge technology plays an imperative role in separating the liquid and solid components of body fluids such as blood or urine. If you’re searching for a high-quality centrifuge instrument, Johnson’s Scale & Balance Co. has some of the best machines on the market.
e) Chemistry analyzers
These devices measure the concentration of proteins, electrolytes, metabolites, etc. in various body fluids.
f) pH Meters
A pH meter is a scale for examining the acidity or alkalinity of urine samples in the medical lab. Atlantic Scale offers a reasonable range of pH Meters for your medical lab. Check them out!
g) Autoclaves
Autoclaves are for sterilizing instruments and keeping tools bacteria and germ-free.
h) Incubators
Incubators regulate temperature, carbon dioxide, humidity, etc. for safely working with cell and tissue samples.
Other fundamental instruments for the lab include hotplates, differential counters, immunoassay analyzers, urinalysis analyzers, gamma counters, microplate readers or washers, DNA analyzers, and point of care analyzers.
What to Consider Before Buying Instruments for Your Medical Lab
Whether you’re searching for a centrifuge or an analyzer, it’s vital to equip your facility with the right devices. Competition has become fierce in the healthcare industry – physicians, hospitals, and patients require a vast range of testing choices. Depending on your medical lab’s unique services, you will need to purchase the finest, most reliable instruments on the market.
Keep in mind a few essential points before selecting any medical lab apparatus:
1. New or Refurbished Instruments
You can opt for brand new or refurbished medical lab devices. Used equipment is refurbished and recertified before it’s sold. Of course, refurbished equipment will be less expensive, but you must weigh factors such as performance. Even though new instruments are quite costly, they’re the best choice for guaranteed consistency and durability. Buying brand new devices means you will be using the latest technology, this could get more accurate and advanced results.
2. The Quality of Results
A medical laboratory apparatus must provide highly accurate and reliable test results. You also want a machine that produces results on time and can handle your workload requirement. The instrument should be capable of processing a suitable number of tests and different types of tests, as well. Make sure to look into emergency and non-emergency test count requirements as well.
3. Useful Features
Medical laboratory instruments come with different features. Be on the lookout for a user-friendly device that has a simple operation. Other factors to consider are walkaway capability, onboard reagent capability, preferred report formats, and barcoding. Furthermore, it includes system failure alarms, closed tube sampling, and the ability to run different samples.
4. The Size of Your Medical Lab
If your medical lab has limited space, search for compact instruments. There are tabletop and under-counter medical laboratory devices, so choose those that comply with space constraints. Most leading manufacturers offer compact yet reliable, durable equipment. As long as it meets the prescribed instrument standards, it doesn’t matter how much space it will consume in your lab.
Author
