HomeHomeHome Improvement TipsWhat Causes Uneven Heating and Cooling in Your Home?
Many homeowners experience the issue of uneven heating and cooling, particularly during the change of seasons. You may find that some spaces are too hot or cool while others are too cool or hot making it difficult to maintain a comfortable indoor climate. This inconsistency can be frustrating and can sometimes also indicate that there may be underlying problems with your HVAC system.
The first step in determining how to remedy your uneven temperatures throughout your home is to understand why your home has areas of both high and low temperature. There are a number of factors contributing to both hot and cool areas in your house; issues with your HVAC system including flow restriction, provide several reasons as to the source of your problem. In this article, we’ll look at some of the most prevalent reasons for the inconsistent heating and cooling found in many homes. We’ll also look at steps you can take to resolve these issues within your home.
5 Reasons Your Home Has Uneven Heating and Cooling
The reason behind some rooms being too hot compared to other rooms being too cold is usually because of an issue affecting your heating and cooling systems. Here are five common reasons that can cause uneven heating/cooling in your home, and what could be affecting your comfort level.
Aging HVAC Systems and Equipment Wear
An old HVAC system can lead to uneven heating/cooling. As the system ages, individual components (like furnaces and air conditioners) will gradually lose their efficiency over time. As these components continue to age, they may find it more difficult to circulate air evenly throughout your house, leading to warm/cold spots.
Furnaces typically last around fifteen years according to Service Titan. If your heating and cooling system is nearing or has already passed this timeline, you should expect that it will likely not work as well as it used to. Because older systems tend to break down more frequently than newer models, an older system might not be able to handle the demands of your family.
Poor Airflow and Ductwork Issues
The way your home is heated or cooled largely depends on airflow. If your duct work is faulty, improperly designed, or obstructed, this may interfere with the flow of conditioned air to certain areas of your home causing an uneven temperature distribution from room to room.
Air loss through leakage results in energy waste, and reduces the amount of heat or cool air generated by your HVAC system. Air ducts located further away from your heating/cooling system will typically receive less air flow than air ducts located closer by making them more difficult to maintain comfortable temperatures. Regular inspections will allow you to discover issues and schedule repairs on time.
Thermostat Placement and Settings
The location of your hvac thermostat has a major effect on how well your system works. A poorly placed thermostat can cause your system to operate inefficiently because it does not reflect the average temperature of the house accurately.
For example, if you place your thermostat next to a window or in direct sunlight, it will report a higher temperature than what is actually occurring in other parts of the house. As a result, when the thermostat reaches its temperature setting the heating/cooling will turn off sooner and leave other areas of the house cold. On the other hand, if you place your thermostat in a drafty or shaded area, it will overcompensate for heat loss from that area and turn on earlier than necessary causing the homeowner to have an uncomfortable home.
Insulation and Structural Factors
When there isn’t enough insulation, it is often due to insufficient insulation. The unconditioned air within a home with insufficient insulation can lead to inconsistent temperatures between various rooms in the house. Attics, basements, and exterior walls are extremely vulnerable to losing or gaining heat through these types of areas.
In addition to the factors involving insulation, other structural factors such as the overall size and layout of the house also affect how cold or how hot different areas within the house feel to the occupants. An example of this is that multi-storied homes tend to experience inconsistent temperature levels due to the heat rising as well as the variation in airflow patterns throughout a home. By improving the insulation between the exterior walls and the internal walls of the house, it is possible to make your home more comfortable and to provide more consistent temperatures inside your home.
The Impact of HVAC Maintenance and Industry Demand
Consistent regular maintenance on your heating and cooling system will assist to prevent an inconsistent temperature throughout your home. Having routine service completed gives your heating and cooling system the best chance to operate at its optimum performance and may also help to identify future problems before they become a costly repair. According to the popular DIY show, This Old House , consumers will spend over $10 billion in HVAC repair and maintenance every year; therefore, regular scheduled maintenance is critical for continuing care of your HVAC system and avoiding costly repairs.
In addition, according to Benchmark International , HVAC installation and repair services are responsible for approximately 60% of the worldwide HVAC systems industry revenue; therefore, the demand for these services will continue to rise as more homeowners are looking for ways to keep their homes as comfortable as possible and save money on energy expenses.
There are many factors that will contribute to inconsistent heating and cooling in a home. Some of the most common factors include the following: age/condition of the equipment; the airflow within the heating/cooling system; the location of the thermostat; the insulation of the house. It is important to correctly identify the problem in order to improve the level of comfort in the home and improve the energy efficiency of your HVAC system.
By performing routine maintenance on your HVAC system and resolving the issues mentioned above, you will be creating a more comfortable indoor environment within your home. By taking the time to inspect your heating and cooling system, you will be able to ensure that you and your family have a comfortable temperature in your home all year long.
