HomeCar GuidesMaintenance & RepairHow to Check and Change Your Engine Oil
Maintaining your vehicle’s engine is crucial for its longevity and performance, with regular oil checks and changes being one of the most essential tasks for any car owner. Proper automotive care not only ensures your engine runs smoothly but also saves you from costly repairs down the road. In this article, we will guide you through the comprehensive steps of checking and changing your engine oil, empowering you to take control of your vehicle’s health and performance.
Checking Your Oil Level and Condition
To begin, park your car on a level surface and turn off the engine, allowing it to cool down for a few minutes. A cool engine ensures that you get an accurate reading of the oil level without risking burns. Once ready, open the hood and locate the dipstick, a crucial tool for assessing your oil’s level and condition.
Remove the dipstick, wipe it clean with a rag, and then reinsert it fully into its tube. After a moment, pull it out again and check the oil level on the stick. The oil mark should be within the indicated range; adding more oil if it’s low helps prevent engine wear and maintains optimal performance.
Inspect the oil’s colour and texture, which provide insights into its condition. Fresh oil typically appears amber and transparent, while dark and gritty oil suggests it’s time for an oil change. According to Finance Buzz, 90% of American households own a car, underscoring the importance of regular oil inspections to keep these vehicles running smoothly.
Draining Old Oil and Replacing the Filter
When it’s time to change your oil, start by lifting your vehicle securely with a jack and placing stands beneath for safety. This allows you to access the oil pan more easily. Once secured, place an oil catch container underneath to collect the old oil.
Next, remove the oil drain plug with a wrench, allowing the oil to flow into the container. This process can take several minutes, so be patient and ensure all the old oil is completely drained. Removing the old oil thoroughly is essential, as it washes away metal shavings and other debris accumulated in the engine.
After draining, replace the oil filter, as it captures contaminants and prevents them from circulating in the engine. According to Statista, the United States oil change services industry generates approximately $12.6 billion in revenue every year, showing the significance of maintaining clean, efficient oil systems in your vehicle.
Refilling with the Right Oil and Final Checks
Once the old oil has been fully drained and the filter replaced, it’s time to add fresh oil. Refer to your vehicle’s manual to ensure you use the correct type and amount for your engine. Pour new oil slowly into the engine via the oil filler cap, checking the dipstick periodically to avoid overfilling.
Start the engine and let it run for a few minutes to ensure the new oil circulates well. This step also allows you to verify there are no leaks beneath the vehicle, which may indicate a loose component. Regular oil changes contribute significantly to the engine’s health, preventing friction and overheating.
After confirming everything is in order, dispose of the old oil responsibly at a certified recycling center. According to Bankrate, drivers of newer vehicles should get their oil changed every 5,000 to 7,500 miles, promoting an efficient and reliable automotive experience. Routine maintenance like this helps prolong your vehicle’s life and enhances its performance on the road.
In conclusion, conducting regular checks and changes of your engine oil is a fundamental aspect of vehicle maintenance that should not be overlooked. By doing so, you ensure the longevity and efficiency of your engine, leading to a smoother and safer driving experience. Equipped with the knowledge from this article, you’re ready to take charge of this essential aspect of automotive care, ensuring your vehicle remains a reliable companion for years to come.
Talha Nawaz is an automotive enthusiast who writes about vehicle customization, car culture, naming trends, and practical ownership guides. He regularly covers car styling ideas, personalization tips, and automotive lifestyle topics for iGuides.
